Help simulate the angle of arrival of the signal
Hello! Help set the angle for the automatic radio compass. Could simulate to the contour of addition
(2,436 Views)
That VI only has a graph and an event structure...
You should give a bit more information on the help you need.
(2,383 Views)
There must be two generators. There is only one frequency - in the frequency range 150 kHz - 1750 kHz, this is the frequency of operation of the drive radio stations. These signals go from the output to the loop antenna, but their amplitude depends on the heading angle. The second generator is an carrier frequency generator, the frequency is 135 Hz. Its signals (direct, sine) and the past phase shifter 90 degrees (cosine) are modulated in the BM signals of loop antenna. Then these signals add up.
(2,366 Views)
