Help resolve Invalid app kind
I am using the app.kind property to determine if the environment is runtime or not. (i have a case statement attached to this, and if in the runtime environment instead of the development environemnt additional code is acted on)
however, I am getting invalid app kind,
there doesn't seem to be much doecumentation on this topic, any help would be appreciated.
Thank You
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,825 Views)
Accepted by topic author eximo
Problem is solved for now, invalid app kind appears if the statement will be generated if the application is run, but the code generating the enum ring is not.
-Regards
eximo
Neuronetrix
(3,823 Views)
Can you elaborate? What code is "generating the enum"?
Do you think there is a bug?
(3,814 Views)
