07-28-2011 10:23 AM
I have a very simple code using the feedback node to make a LED stay off when both of the push buttons are off; otherwise, the LED starts blinking. I need like for the LED to show "NO ERROR" label when it is not blinking, and to show "ERROR" label when it starts blinking. But I have not been able to figure out how to do this without having two different LEDs.
LT42
07-28-2011 10:41 AM
Your description is very confusing.
You can programmatically change the caption or boolean text. You could also use a cluster of a LED and a string indicator for more flexiility. Please show us your code so we can better understand what you need.
07-28-2011 10:58 AM
Blinking = attention-getter - got it. However, if there is no error, I would not use any caption/label, or rather I would make the caption/label invisible (with a property node), and then make it visible again when there is an error.
Also, just making the ON text read "ERROR" should work too, unless you use steady on for something else.
Michael Tracy
07-28-2011 11:05 AM
07-28-2011 01:06 PM
Peter D,
I think that is the functionality that I am looking for. The only problem is that I have LabView 9, and the file is in a newer version. Would it be possible for you to uploade it in a different version?
Thanks.
07-29-2011 03:06 AM
07-29-2011 10:24 AM
Thank you very much. That was very helpful!
LT42
07-29-2011 10:28 AM
