Help please with Converting LV 5.x VI to one that can be read by 8.5
I have seen some earlier posts where, in one case mikes81, and in another Dennis Knutson, was able to provide a conversion of VI from LV 5.x to something that can be opened in 8.5. I am new to LabVIEW and I need to update early work but don't have the early versions. I would be very greatful if someone could provide an updated version of the attached VIs. I am not sure at this point which ones are relevant but there are only 3. Thanks in advance for any help
(2,841 Views)
Hi stlchem,
here you go... A lot of subvis are missing, so you might not be able to run them!
But be aware that parts of those vis may go to the Rube-Goldberg threadSmiley Wink
(2,835 Views)
