Exporting a Changing Front Panel (i.e. Virtual Scope)
I have an LabVIEW application that displays (using a virtual oscilloscope) a modulating waveform and some information regarding our devices.  The front panel is a the virtual oscilloscope with all the controls hidden.   There are no controls available to the user.
I need to distribute that application to 200+ non-technical sales personnel.  The sales personnel are not very tech savy.  I can generate an application that would perform this function and include the run time library with the install, but I was looking for a less cumbersome and more bullet-proof solution.  Could I generate a .mpg file of the LabVIEW front panel?  Could I use a screen capture program?  Could I create a PDF document?
Any suggestions would be greatly appreciated
(2,723 Views)
Problem solved.
I was able generate a flash file using Instant Demo program (called instant demo) that captures screen shots of your screen or program window.
Demo software is available at.
http://www.instant-demo.com
(2,706 Views)
