Help needed with temperature measurement
hi guys
I need some help with temperature measurement. I've got a NI PCI 5229 card and a powertransmitter. The power transmitter is programmed to output a 4-20mA (0°C - 100°C) signal. How can i get labview to convert this mA signal to displaying it as temperature? Please include a lot of detail as I am a first time labview user.
Thanx
(3,037 Views)
Hi Jaco,
calculate gain and offset for your values. After you have this values, you can calculate your temperature. See the attached picture.
Hope it helps.
Mike
Message Edited by MikeS81 on 05-18-2008 02:44 PM
(3,033 Views)
The equesion is :
(Temperature)=((mA read)-4)*(100/16)
But that is true only, if the output is linear
(3,010 Views)
Thanx. The line isnt linear. Can I use the calibrated data and determine the line equation? How many calibrations should I do to accurately determine the equation?
(2,987 Views)
Hi Jaco,
create an array with your inputs and your associated outputs. From this values you can interpolate the values you need.
Mike
Message Edited by MikeS81 on 05-18-2008 09:31 PM
(2,983 Views)
You probably need only a few measurments. Lets say around 6.
But that info should be available by the manufacture, also.
You can find the line equation with Excel, or Labview. I had seen a example vi, doing that. Check labview examples....
(2,965 Views)
