Help needed: Memory leak causing system crashing...
Jeff,
Yes apprently I am in the second group (with very little/no hope to be in the 1st one in the near future) :).  I am working on get my code better from the basics but it sure takes long time for a newbee like me. Thanks for your suggestions!
Harry
Message 21 of 23
(566 Views)
I added the shift register. This ensures that each time you operate on a task you're working on the most recent task. However, because the diagrom is so large the wires are kinda messy since it has to travel the whole length of the loop. You were missing the urrin and out VIs so I couldn't tell if those were correct.
Matt
Message 22 of 23
(563 Views)
Matt, thanks!!! I know it's definitely not a pleasrue to check a vi like mine!
The CurrIn and CurrOut vis are "generated" from DAQmx assistance. I put them here and hope they are ok. Thanks again!
Rgds,
Harry
Message 23 of 23
(555 Views)
