Help needed: Can anybody convert a hit7104g.llb from LabView 7 into a dll for LabView 6.1??
Gents,
I am an absolutley beginner in LabView, but working very hard on it to get a progress.
I"ve got great help here at this pages how to find out the first steps installing 2 DSO Scopes Hitachi VC-7104, which are connected via PCI-GPIB.
Equipment, settings  and communication inside the automation explorer is working perfect.
I found a free LabView version inside a PC Magazine, its the LabView 6.1 and I want to let them communicate
with my DSO's.
There is a driver available but for only for the LabView 7 version.
Can anybody convert this file and explain to me how to install it later at LabView 6.1 ??
I would be very happy, because my old method was writing data's into the PCMCIA-SRAM card at the DSO
and pull out it for reading outit later in a PC, crazy method.
Best regards from Germany!
Thomas
(3,015 Views)
I am converting them.
Will post soon
R
(2,983 Views)
Ok, great!!!Many THX !!
Meanwhile I read more in the LV6.1 manual.
Thomas
(2,976 Views)
A bit messy since I was trying to do it quickly, but all the files should be in LV6.1 in their respective folder.
Let me know how it goes.
R
(2,967 Views)
Joe,
Moved all folders from your file into the folder C:\Programme\National Instruments\LabVIEW 6.1\instr.lib,
same path were the HP34401 instrument is.
Then tried a function, like the GO NOGO function and now the communicaton is perfect between the DSO and LV 6.2.
All other VI from your folders works also wooopiyyy!
Many thanks for your  job here !!
I will try out now to get a screen copy from my DSO into the LV.
My goal is to create a file on the harddisk which contents an event from a measurement with the help from the Go-NOGO.
For me, its ok to have that DAT files first and then, lets see.
Best regards !
Thomas
(2,957 Views)
Glad it worked out.
(2,951 Views)
