Enable an item in menu ring
Good Morning
I have problem in enabling a particular item in menu ring.
I have disabled few items in the ring control using the Property node[Disabled Items]. I want to enable those disabled items one by one(whenever i want)
Message 1 of 14
(4,535 Views)
Hi Veeru
Just use the property node [Disabled Items] again, but remove the element you want to enable from the array.
Daniel
Message 2 of 14
(4,533 Views)
Thanks Daniel
You mean removing the element from an array.(We can do using the Insert and delete lement from array)
I have programmed in a way,there is separate button for each item in the menu ring.By pressing a button the corresponding disabled items needs to be enabled.
Message 3 of 14
(4,526 Views)
The [DisabledItems] property is an array. If you want to disable all elements, the array will be [0,1,2,...,# elements-1].
To enable element 2, search for '2' in the array and remove it. Write the array back to the [DisabledItems] property.
See code snippet.
Element to enable contains the index of the ring item to enable.
Message Edited by dan_u on 07-23-2008 10:56 AM
Message 4 of 14
(4,521 Views)
Thanks Daniel
Ur ex works very fine for me
Message 5 of 14
(4,500 Views)
hi
i have difficulty to add an item to ring control.
In the attached vi, i am trying to add and delete an item in menu ring.Deleting item part,i have used because just i like to delete an item by specifying the indx number.
In the add part i have problem,pls help me with this
Message 6 of 14
(4,479 Views)
Try the attached vi. You needed a stop event, a shift register to update the ring items and a way to index adding new elements.
R
Message 7 of 14
(4,477 Views)
Thanks Joe
Message 8 of 14
(4,474 Views)
Joe
Sorry,sometimes it is not deleting the correct item(when i checked in the properties[Edit Items>>sequential values is getting unticked automatically even if we set in tick)]
Message 9 of 14
(4,472 Views)
OOps.. Sorry.. you can't have the same number twice.
Now has a warning and will not duplicate numbers.
R
Message 10 of 14
(4,468 Views)
