02-08-2008 08:45 AM
02-08-2008 09:01 AM
02-11-2008 12:45 AM
02-11-2008 07:59 AM - edited 02-11-2008 08:01 AM
I would second the DSC module and Citadel recommendation, but it depends on what you want. Do you just need to stream the data to disk?? Do you want historical data trends, and for how long of a timeframe?? Does it matter if the hard drive crashes and your history data is lost?? How often do you want to save a datapoint, every minute/second, only on a value change?? Is all of the hardware in one location?? How many different devices do you need to monitor??
You could do this with plc hardware or with NI fieldpoint hardware. If you already have plc hardware in your facility, I would use that and the DSC module with an OPC server.
