Error 8 occurred at Invoke Node in AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Hi there,
Hope someone can help me.  I recently upgraded to LV 8.5 and am having a problem building a .exe which has a subvi in it that opens in a new dialog window.  When I try to build this I get the following error:
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
NI-488:  DMA hardware error detected.
Method Name: Build:Application
I have built the .exe with the same subVi but without opening it in a dialog window and it works fine., so the problem seems to be linked to the inclusion of the dialog window.
Any advice greatly appreciated
Regards
Tadhg
(4,569 Views)
UPDATe:  I can get the .exe to build but now I get an error when I run teh .exe which is shown in the picture attached.
(4,564 Views)
Could you include your project here please, that way I can take a look at it and discover why this error is popping up and where.
(4,544 Views)
managed to fix this problem by selecting the 'always include' option for the sub vis when building hte .exe.
thanks
-t
(4,542 Views)
Okay smashing, Thanks for letting me know.
All the best,
(4,540 Views)
