Help me about Array
Hi! I have a question about how to use the Array!
When I first run, I want to select and show the entire data to the array, and then the user will search and show the selected data!
Is there any way you can combine the two arrays in the picture?
Message 1 of 13
(4,639 Views)
Accepted by topic author adavb
Hi adavb,
Yes!
Wire the "array" data through the event structure and place the "array" indidcator after the event structure. Now you can use a TimeOut event case to show "first" data, and you can replace the array data inside the "Search" event case…
(This is basic DATAFLOW programming!)
Message 2 of 13
(4,628 Views)
Sorry.. GerdW
plz Show me a Example...
Message 3 of 13
(4,604 Views)
Hi adavb,
example:
The shift register holds the array data, and you can manipulate that data in the event case(s)…
Message 4 of 13
(4,594 Views)
Thanks!! My bro
Thanks you very much!!
감사합니다(thanks) GerdW
Message 5 of 13
(4,589 Views)
Hi guys!
I want to make each button in a red space.
Somebody help me.
Message 6 of 13
(4,569 Views)
Hi adavb,
you really need to explain that "red space buttons".
(Are we changing to Sci-Fi topics?)
Message 7 of 13
(4,553 Views)
Sorry, I thought I uploaded it.
Message 8 of 13
(4,542 Views)
Hi adavb,
basic LabVIEW knowledge: in an array all elements have the same datatype and share the same properties! You cannot mix strings with buttons in a string array!
You could create an array of clusters of [string, string, string, button]…
Message 9 of 13
(4,533 Views)
I have one more Question.
Is it possible to get the data from an array click?
Message 10 of 13
(4,525 Views)
