Help me about Array
Hi! I have a question about how to use the Array!
When I first run, I want to select and show the entire data to the array, and then the user will search and show the selected data!
Is there any way you can combine the two arrays in the picture?
Message 1 of 13
(5,008 Views)
Accepted by adavb
Hi adavb,
Yes!
Wire the "array" data through the event structure and place the "array" indidcator after the event structure. Now you can use a TimeOut event case to show "first" data, and you can replace the array data inside the "Search" event case…
(This is basic DATAFLOW programming!)
Message 2 of 13
(4,997 Views)
Sorry.. GerdW
plz Show me a Example...
Message 3 of 13
(4,973 Views)
Hi adavb,
example:
The shift register holds the array data, and you can manipulate that data in the event case(s)…
Message 4 of 13
(4,963 Views)
Thanks!! My bro
Thanks you very much!!
감사합니다(thanks) GerdW
Message 5 of 13
(4,958 Views)
Hi guys!
I want to make each button in a red space.
Somebody help me.
Message 6 of 13
(4,938 Views)
Hi adavb,
you really need to explain that "red space buttons".
(Are we changing to Sci-Fi topics?)
Message 7 of 13
(4,922 Views)
Sorry, I thought I uploaded it.
Message 8 of 13
(4,911 Views)
Accepted by adavb
Hi adavb,
basic LabVIEW knowledge: in an array all elements have the same datatype and share the same properties! You cannot mix strings with buttons in a string array!
You could create an array of clusters of [string, string, string, button]…
Message 9 of 13
(4,902 Views)
I have one more Question.
Is it possible to get the data from an array click?
Message 10 of 13
(4,894 Views)
