Help building an executable that uses a factory pattern
Thanks Mike. After doing some more research I found the "Current VI's Path" VI in the open G toolkit. It always returns path+current VI. I can just hook it up to the strip path once, then use it for executable files and the LV Application Directory.vi for the base installation path.
Thank you Everyone for the help!
Simon
Message 11 of 11
(814 Views)
