Help Database Connectivity Toolkit INSERT Cluster
Dear LabVIEW Community,
Please help me! What is the best way to use the "DB Tools Insert Data" with clusters of different number of elements.
I do not want to write values for same fields of a table every time.
Do I need to create a cluster for each kind of INSERT?
Best,
MOJO
(609 Views)
I generally create the SQL query myself and use Execute Query instead. That way you can e.g. loop through as many fields as you need at the moment.
Qestit Systems
Certified-LabVIEW-Developer
(585 Views)
