Having prolem with CRIO
Hi guys,
I'm using Compact RIO9066 and NI C series module 9205 and 9264 to do the measurement in the project.
I've installed all the software required(Labview2015, Real-Time module 2015, FPGA module 2015 and
CRIO drive devices) and connect the RIO9066 to host computer with USB cable and put NI 9205 and 9264
into the slot of the RIO9066.
The problem is that I can find the CRIO9066 in the MAX but cannot find the NI 9205 and 9264, I don't know
what's going on there.
I would appreciate it if anyone could help me!
Regards!
Once for all!
(2,964 Views)
Accepted by Vidasll
Hi Vidasll,
you don't find any modules in MAX.
You will find them in your LabVIEW project once you included your cRIO target in the project…
Hint: Use a red wire for Vsup of your power supply… 😄
(2,946 Views)
