Have somebody try to implement in LabVIEW FPGA a logic analyzer?
Hy,
I want to implement in LabVIEW a logic analyzer/ digitizer using NI PXI as hardware. Have somebody try to do this or have an example? I will appreciate any opinion or support.
Thanks !
Message 1 of 8
(4,130 Views)
xenopol,
Do you currently have PXI hardware that you're trying to implement your logic analyzer/digitizer appliction with or are you looking for PXI hardware suggestions?
There is a helpful shipping example called "Logic Analyzer.vi" that comes packaged with the NI-HSDIO driver.  You can locate this in Example Finder (Help > Find Examples).
Jared R.
Precision DC Product Support Engineer
Message 2 of 8
(4,104 Views)
I have the PXI hardware and I try to implement a logic analyzer... I also have LabVIEW2010 software...I search for the example that you suggest me but I don't find it in LabVIEW2010...I would appreciate if you post the example here.
Thanks !
Message 3 of 8
(4,098 Views)
xenopol,
Can you provide me with the model number(s) of the PXI modules that you're working with?  There is a wide variety of modules available and I'd like to make sure that the one you're using is appropriate for this application.  Thanks!
Jared R.
Message 4 of 8
(4,096 Views)
I work with NI PXI-1042...and the module PXI that I use to acquire digital data is NI PXI-7811R Reconfigurable I/O.
I want to read digital data from Serial and I2C transmission...
Message 5 of 8
(4,085 Views)
Terminolgy may be getting in your way.
A logic analyzer will generally monitor multiple digtial lines at the same time ... like a 32 channel oscilloscope.
A Protocol Analyzer on the other hand will monitor a data line and interpret the data as bits sent one after the other.
Ben
Message 6 of 8
(4,081 Views)
I understand...I wanna implement a logic analyzer to monitor multiple lines...and I wanna test it to some circuit which comunicate Serial and I2C..
Message 7 of 8
(4,078 Views)
There are examples for I2C on our website.  As far as serial, that depends on what type of serial you are talking about.  I would still look on our IP network to see if the examples there serve your purpose.  The website is ni.com/ipnet
Let us know if this is helpful.
Ryan
Message 8 of 8
(4,065 Views)
