04-14-2015
01:57 AM
- last edited on
06-17-2025
12:47 PM
by
Content Cleaner
Hi all,
I am using the Harmonic XControl found in the link below. It does not seem to work with LabVIEW 2011 or later versions. Can anyone help me fix this issue.
http://www.ni.com/example/31404/en/
Thanks in advance.
04-14-2015 05:02 AM
04-14-2015 06:11 AM
Thanks for your reply, PFA the error codes.
04-14-2015 06:19 AM
04-14-2015 06:26 AM
The facade vi has many broken sub vis, i am not able to figure out the issue.
04-14-2015 06:49 AM
Hello Mike,
PFA the error code for all the broken SubVIs. The error seems to be common for all the broken SubVIs. I couldn't find any threads on how to fix this issue. Is there a work around for this. I so badly want to use this XControl for my application.
04-14-2015 07:25 AM
06-28-2016
08:01 AM
- last edited on
06-17-2025
12:50 PM
by
Content Cleaner
I have the same problem with LV2014.
It seems to be a problem with LabView error:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/errors/run-time-type-not-propagated.html
Is there a version corrected for LV2014 ?
Thank you.
