Handling events in sub VIS
I am trying to capture the events in a sub VI. But somehow the event is not being captured.
Thanks in Advance
LabVIEWan
Message 1 of 8
(4,203 Views)
Have you had a look at this link:
Handling Events Generated in a SubVI
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 8
(4,181 Views)
This nugget by Ton really helped me get a handle on Dynamic Event Registration. Here is a preview...
Ben
Message 3 of 8
(4,160 Views)
Yes I have seen this. But I want the Sub VI to be launched only when the user wants to call it.
Message 4 of 8
(4,138 Views)
Smiley Indifferent
That is my puzzled look.
Since we missed the mark and now you are off in a new direction... Could you please stop and describe what you are looking for so we don't waste your time?
Ben
Message 5 of 8
(4,116 Views)
I want the sub VIs events to be captured by the main VI. But the sub VI should be launched only after the user calls it.
Message 6 of 8
(4,092 Views)
If you are directly calling the sub-VI then you can right-click on the sub-VI and then click on 'show front panel when called'. If you are dynamically calling a VI, then you can open the front panel using property node.
event handling will be take care of anything untill and unless the VI is executing.
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
Message 7 of 8
(4,063 Views)
Please take a look at this thread where I show how I implement events in sub-VIs.
It is still dynamic event registration.
Ben
Message 8 of 8
(4,034 Views)
