Handling a state machine using a single button
This should get you pretty far down the road.
Tim
GHSP
Message 11 of 23
(2,301 Views)
Accepted by nikvl
OK this one is actually closer to what I think you are looking for. Change the timing on the timeout of the event structure to execute the loop faster.
Tim
GHSP
Message 12 of 23
(2,295 Views)
I found an example of a Event State Machine by Bob Schor and tried modifying it, but I ran into the problem when I click OK, it goes straight into the timeout rather than generating an event.
Right now most examples contain a pause or idle state but I don't want the program to be idle when I press OK after the Run is clicked.
My aim is to:
1) In the Init state, some things are initialized and then it goes to idle state and wait for user button press
2) User press Run to start the state machine (This button should only be done the first time)
3) User press OK and next state to Process 1 should be triggered WITHOUT pausing (The timeout for Process 1 should be same as Run but if I make a timeout case for Process 1 (which is identical to Run anyway) I'm uncertain of how to wire the same OK button to stop that loop
4) I didn't create more entries but if User clicks OK again it should go to process 2 and so on (until it reaches a certain Process X and the Finish event is triggered automatically or manually at any point)
p/s: please ignore the 'default if unwired' cases, everything will be wired in the real program
Message 13 of 23
(2,267 Views)
Did you look at the second example I gave you? It does not stay idle. Take a look. If you need the loop to go faster just change the time on the time out loop to make it go faster.
Tim
GHSP
Message 14 of 23
(2,260 Views)
Hi Tim,
thank you for the example but it did not work when I pressed any of the buttons (except Exit). I think it might be stuck at the timeout case too. The 'Next' button didn't generate an event to update the Current process. I think the Case structure should be inside the event structure, no?
Message 15 of 23
(2,254 Views)
You need to hit start. That loads the states into the array and starts the process. Next make it go to the next step. Stop stops the process. Exit will exit the program.
Tim
GHSP
Message 16 of 23
(2,247 Views)
Yes I did that and tried with different timing. Current step shows 'none' while current process remain blank no matter if I press start or next.
Message 17 of 23
(2,242 Views)
Did you add states to the array on the front panel?
Tim
GHSP
Message 18 of 23
(2,238 Views)
Yes, so then the start works, and then nothing else, not even the exit anymore. Because the it goes to the next state in the case selector and there's no event case to detect any other button press.
Message 19 of 23
(2,230 Views)
I fixed that on the second example v
Tim
GHSP
Message 20 of 23
(2,227 Views)
