Handling a large array of integers
I have a 1-d array with upwards of 1 million elements. I need to "pull out" every other element and put it in a new array.
Right now I have a "for" loop that divides the index of the loop by 2. If there is no remainder it ignores that index. If there is a remainder it indexes the array at that element and puts the element into a new array.
After ~300,000 elements the program slows down considerably.
Any suggestions?
Steve
(3,376 Views)
Accepted by topic author rinscneutrons
Try the Decimate Array primitive.  Use it with two output arrays (default - it is expandable) and do not connect the one you do not need to use.
Lynn
(3,373 Views)
THe slow down is probably due the build array repeatedly allocating memory.
Try Lynn's suggestion since it accomlishes he same thing but with a sinlge operation.
Ben
(3,371 Views)
That did the trick.
Steve
(3,337 Views)
