HTTP Client with Authentication
Dear Community,
I want to connect to a httpserver located on a device via LabVIEWs http- client- functions. The url I have to connect to is https based. I am transferring the functionality shown in the attached  python code to labview.
When I run the python code the connection is established and I receive the response: 200 ok.
When I run the labview code I get the error "404 Not found" with the message "Invalid hashcash".
Any ideas what went wrong?
(3,193 Views)
Accepted by labviewette
The items you are passing are not header elements but th ebody of the POST. You need to create the JSON body with those attriutes and pass that to your post call.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,155 Views)
Yep, that did it.
Thanks Mark.
(3,112 Views)
Hi!
Just to let you know: There is the JSON-to-Text VI in the string palette. Input in this case would be a cluster with three text controls labeled loginName, password and hashcash..
(3,063 Views)
