Showing results forĀ
Search instead forĀ
Did you mean:Ā
HELP!!! Data input???
Help! I'm an undergrad at OSU and I've just started research. I've been thrown in with the sharks and it's time to sink or swim. I need to learn how to use incoming data (a simple voltage input) to show on a graph whether or not the voltage is going above or below a certian level. Please, anything would help right now....
(3,343 Views)
Accepted by tvajas
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,342 Views)
It is NOT that we are unwilling to help...
But we are not a homework service.
Review the getting started material... put something together and if you are having trouble with specific parts of your VI that you have started, there is help aplenty to answer specific questions and give tips and hints.
but do not think for a minute that your prof is not lurking here too!
See this thread on how to get cooperation
Paul
(3,332 Views)
The links provided in another response are excellent.
Another great resource is LabVIEW's built-in Example Finder.  You can find this through the Help menu.
Have a search for analog DAQmx to see some code for capturing your voltage input.
Look for "compare" for info on how to......compare stuff to other stuff.
Good luck with your project.
Patrick Allen: FunctionalityUnlimited.ca
(3,311 Views)
(3,311 Views)
