Guys, I Messed Up...
Hey All,
So recently I rewrote the Write BMP File vi to skip the write to file part and just add the BMP header to files. Unfortunately, I forgot to save my rewritten vi as a different vi, and I overwrote the Write BMP File vi...
Could somebody attach the default copy of that vi for me?
Thanks all.
(3,487 Views)
What version of LabVIEW?
(3,479 Views)
2012
Thanks!!
(3,472 Views)
SP1, 32-bit if that makes a difference.
Thanks again!
(3,470 Views)
Accepted by Drewskie
You will need to replace the entire LLB file.  Put this file here: C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\picture
(3,461 Views)
Don't worry we all make mistakes.  In the future if you do something like this and make changes to LabVIEW code, you can perform a repair install of LabVIEW and it will replace all your files with the ones from the fresh install.
(3,448 Views)
Ahhh, that's a good idea. Thanks man!
(3,443 Views)
