Graphing - Using Text Labels on the X Axis
I am trying to create a Run Chart that shows the result of a parameter vs. the units’ serial number.  For example if I wanted to graph the number of apple, oranges and grapes sold on a particular day I would have Apples, Oranges and Grapes going across my x axis and qty of each going up the y axis.  I have attached a simple sample of what I am trying to do but in Excel.  I just cannot figure out how to make the x axis accept strings.
Any suggestions would be appreciated.
Paul
(4,269 Views)
I would hide the x-axis and place a horizontal slide underneath the graph set to text lables (You can hide the slide and only show its scale).
Keep the ranges between the hidden x-axis and the scale axis sychronized via property nodes.
I agree that it would be nice to have graph axes with text labels. There are many possible uses.
You can make product suggestions at the Product Suggestion Center ! 🙂
(4,259 Views)
Well, Christian is again faster. 😠
But that's normal : as a 3 gold bar official enthusiast he must be more efficient.
Anyway here is the solution I was developing, since a piece of code is always better than a lot of explanations 😉 🙂
No need to comment...
Chilly Charly    (aka CC)
(4,251 Views)
The slide idea is nice but when you use the graph zoom from the graphs palette controls how would you sync up the property nodes?
(3,663 Views)
