Graphing Difficulties
I have a Kiethley2100 and a Kiethley199 that i'm trying to use tgether to plot two different voltage curves, HOWEVER, I'm unable to get the graph to display anything but the current voltage. I know that's worded funny, but the graph has a point that sits on the 0 mark for time and moves up and down as voltage changes, but it refuses to plot the past points. I understand how to draw lines between two seperate points on the graph (interpolation line). Is there a way to format the X axis to show the correct time for which the points were taken?
(2,942 Views)
Hi Chaines,
how do you graph the data? Do you use a graph or a chart?
Probably you use a graph when you need a chart... Or make your own buffer using a shiftregister.
(2,939 Views)
What's this shiftregister thing? How do I get to it / learn more about it? And when I tried a chart nothing popped up at all.
(2,905 Views)
Accepted by Chaines
Hi Chaines,
it sems you're very new to LabView. So you should:
- read the help and always switch on the context help
- check for the eamples that come with LabView
- take the online courses (for free) in the academics section
You can create shift registers by right clicking the border of loops (for/while)...
Message Edited by GerdW on 06-20-2009 09:00 PM
(2,903 Views)
