Graphing Arrays
Message 11 of 20
(1,584 Views)
That would work great however I need it in the format that I displayed in the first picture I attached.
Message 12 of 20
(1,581 Views)
Done Like this
Tim
GHSP
Message 13 of 20
(1,572 Views)
Thats right on track of what I need.  The only thing is that its cutting the time from some of the data points.  If you notice in the Test File, there is a time followed by a collected data point, then on the same line another time (fractions of a second later) followed by another time until all the channels have collected a data point then it returns to a new line.  So what happens is, when the second channel collects a data point, the first channel stays at the same value until the rest of the channels have collected data.  Once channel 1 gets its new data point, then the value changes while the rest stay the same. If you notice in my string file, the data point stays the same until that specific channel gets a new value.
Message 14 of 20
(1,566 Views)
Well I have given you a way to take things apart and make the string array. You should be able to take that and put it into a loop to do the rest of the processing or atleast give it a try. I can and will be happy to help you refine what ever you come up with but I would like to see you try first.
Tim
GHSP
Message 15 of 20
(1,554 Views)
Your file format is nothing like what you showed in the original figure or what you said! You said you the date was in the first column, time in the second, and the collected data in the following columns. You said nothing about the date and time columns repeating, and that's not even shown in the figure in your original post. You also said you were using 4 spaces as your delimiters, but your uploaded text file shows commas. In the future please upload the file in the first place so we can see what you're actually parsing instead of guessing and wasting time. Smiley Mad
While aestat's code can be improved to not require the Build Array (which creates memory thrashing), he's correct that you basically have what you need.
Message 16 of 20
(1,552 Views)
Apparently you still don't understand the concept that is going on here.  If  you take another look at the text file that I did upload, that is the original file that I get from a data aquisition unit.  I don't know where you see times repeating because they dont.  Again, the text file has nothing to do with the original issue I posted.  I mentioned that I have a string file, columns seperated by 4 spaces.  I need this string to be an array (with a 4 space delimiter from the string file!)
If you read my other posts, I said that the original text file, regardless of the format, was parsed to the string file that i first posted.  If you feel that I am wasting time then its simple, dont post!
As far as aestat's code, I appreciate what he sent.  I've been trying to manipulate it to work for what i need.  And it's not what I need.
Message 17 of 20
(1,545 Views)
You have posted exactly one file and that is clearly comma separated with times in multiple columns. If you converted the file to that string and then want to extract some columns, you are doing an unnecessary step since what you asked for was the timestamp information and the numerics. What you have been provided with is the direct method to do that. Do NOT refer to what you have in the first post as a file. It is a string indicator.
Message 18 of 20
(1,538 Views)
Message 19 of 20
(1,505 Views)
How would you have done this? I would love to learn how. This is the only way that I know how to do this.
Tim
GHSP
Message 20 of 20
(1,452 Views)
