Graph multiple 1D arrays of different lengths of the same graph without adding zeros to the X values without Y values
k sir as u said i hav zipped two files in which the sensor has sent me these files ........
thanking you
LAKSHMAN C G
Message 21 of 51
(1,569 Views)
can anyone tell me how to monitor a folder i.e a program shd always keep on checking if tr is a file or nt in the specified directory if present it shd process otherwise it shd b quit cn any one help me in tis regard??
thanking you
LAKSHMAN C G
Message 22 of 51
(1,567 Views)
hi tr.....!!
since i am using 7.1 version m nt able to find a fnt called "check if file or folder exits " in the selected path ,so cud anyone plezz help me in this regard ,humble request,plezzzzzzzzz!!:mansad:Smiley Indifferent,i hav also attached my code ,since m a begginer in lab view i wud always welcome ur feedbacks .........
 thanking u.......
thanking you
LAKSHMAN C G
Message 23 of 51
(1,554 Views)
Use :"file/directory info" (or whatever it was called in the 7.1 days).
Look at the error output. If you get an error, the file does not exist.
Message 24 of 51
(1,545 Views)
thank u soo much sir!! i got the soln fr tis ..... Smiley Happy
thanking you
LAKSHMAN C G
Message 25 of 51
(1,540 Views)
Setty,
Please type your messages using real English words and not "text-speak".  They are difficult to understand and are not professional looking.
A plea for full words
Message 26 of 51
(1,523 Views)
i appologise for the inconvinience caused by me , i do type full english words now onawards and make feel simple... thanks for your concern on me....
with regards
LAKSHMAN C G
thanking you
LAKSHMAN C G
Message 27 of 51
(1,506 Views)
hello sir,
can any one tell me what is the actual use of property node .........!!
i went through many NI examples could not get what is property node and its use ,so i request anyone to help in this regard
warm regards
LAKSHMAN C G
thanking you
LAKSHMAN C G
Message 28 of 51
(1,496 Views)
The property node is used to set a property of a control or indicator.  There may be dozens, or even hundreds of properties for a particular control depending on its type.  Properties could be position, size, visibility, color, display format, .....
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 29 of 51
(1,485 Views)
hi ....!!
thanks a lot for clearing the concept of "property node"/////................Smiley Happy
thanking you
LAKSHMAN C G
Message 30 of 51
(1,473 Views)
