Graph multiple 1D arrays of different lengths of the same graph without adding zeros to the X values without Y values
1.I have used TCP listen.vi and TCP write.vi send control command to machine.
2.The machine can receive it and return data to network.
3.The TCP Open Connection.vi occur error 63,so that i can't receive return data.
anyone knows please help me. THANKS.
Error 63 occurred at TCP Open Connection in TCP communicator.vi
Possible reason(s):
LabVIEW: Serial port receive buffer overflow.
LabVIEW: The network connection was refused by the server.
wat ever i have attached acts as a receiver and on the other end i have used NI example active.vi as the other end...
thanking you
LAKSHMAN C G
Message 31 of 51
(1,271 Views)
This seems to be a completely unrelated question, so you should have started a new thread instead of adding to an old thread that is already marked as solved.
Where did you get the attached VI? It seems to be very old and has some very questionable conding constructs (horrible colors, greedy loops, race conditions, convoluted logic, dead code, etc.). You also only attached one side of the communication. What are we supposed to do with it?
There is no way to debug that beast, so let's assume that it actually works correctly. As a first step, you might want to check your firewall settings.
Message 32 of 51
(1,252 Views)
HI FRIENDS,
AS I AM VERY NEW TO LABVIEW ,I HAVE JUST STARTED MY CAREER IN LABVIEW HAVING AN EXPERIENCE OF 6 MONTHS SINCE I HAVE PLANNED TO WRITE MY CLADD EXAM , I WUD LYK SOMEONE TO HELP FOR THE BELOW ATTACHED doubt.VI FILE HERE CAN ANY ONE OF YOU TELL HOW THE ACTUAL DATA FLOWS INTO THE FOR L0OP ...I SAW THIS QN IN EXAMPLE PAPER SO I WUD REQUEST ABY ONE OF U TO EXAPLAIN THE DATA FLOW IN THIS EXAMPLE ...
THANKING YOU
WITH REGARDS
LAKSHMAN C G
thanking you
LAKSHMAN C G
Message 33 of 51
(1,209 Views)
Hallo lakshman,
- no need to cry out loud!
- no need to highjack an old and totally unrelated thread!
- What are these words: "WUD LYK L0OP QN ABY U"???
- Have you tried debugging by highlighting in your 6 month LabVIEW career so far to examine dataflow?
Message 34 of 51
(1,207 Views)
@GerdW wrote:
Hallo lakshman,
oh ! sorry for ma shortcut language...you get the corrected request here ...
 Smiley Happy
thanking you
LAKSHMAN C G
Message 35 of 51
(1,200 Views)
hello !!
can any one tell me what is the main difference between the enum and ring type...plezz
thanking you
with regards
lakshman c g
thanking you
LAKSHMAN C G
Message 36 of 51
(1,176 Views)
Hi lakshkman,
- an enum enumerates several items (like {Mon, Tue, Wed, Thu, Fri, Sat, Sun}) and it's only editable while development time
- a ring stores numbers and connects them with a string (for display purposes) and is editable at runtime
Message 37 of 51
(1,173 Views)
hey gerd
i got it clearly by your description .....Smiley Very Happy
thanking you
LAKSHMAN C G
thanking you
LAKSHMAN C G
Message 38 of 51
(1,168 Views)
hello
can anyone tell me how to disable the key "ctrl+e" such that it should not show the block diagram wen ctrl+e is pressed..
plez as early as possible...
thanking you
lakshman c g
thanking you
LAKSHMAN C G
Message 39 of 51
(1,149 Views)
hello
can anyone tell me how to disable the key operation "ctrl+e" ,such that it should not show the block diagram when "ctrl+e" is pressed..
thanking you
lakshman c g
thanking you
LAKSHMAN C G
Message 40 of 51
(1,140 Views)
