07-13-2016 07:42 AM
Hi!
Has anywone managed to change the scale name label vertical arrangement for a graph or chart? Error 1453 is returned (LabVIEW: You may only set the vertical arrangement on a label, caption or free label.) It's very annoying that the Y scale name label is stuck to counterclockwise.
07-13-2016 08:13 AM
I will speculate ....
Are you setting the "Ative Scale" prior to trying that?
You wil get that error any time you try to act on SOMETHING that does not exist. I saw that error when trying to set the properties of a plot that had never been created.
Ben
07-13-2016 09:21 AM
Yes Ben, I have tried that with the same result.
07-13-2016 09:28 AM
@LucianM wrote:Yes Ben, I have tried that with the same result.
Thank you for the lesson LucianM
I have never looked uner that rock previously and never realized that proerty did not work.
Thank you!
Ben
07-13-2016 09:45 AM
And according to what it says here it should work since a axis label is a lael.
Would like to speculate that this becomes a "documentation bug" in the end?
Ben
07-28-2016 12:52 AM
I contacted NI support and they told me that it's a known issue and it's set with low priority. So if anyone else is annoyed by this bug can make some "noise" on this topic and maybe the priority will increase:)
Regards!
07-06-2022 01:36 PM
Looks like this is still an issue, I am unable to set the vertical text for slider marker text.
