Graph borders problem
If the graph(waveform/XYgraph) background including gridlines(major and minor) is set to white and its control image is used in print report the top and left borders are filled with lines, while the bottom and right are not.can it be filled all sides or can they be removed on all sides.find the attched image for the graph image.Attached is the vi used for it.iIm using labVIEW 8.5.1
Message 1 of 10
(4,947 Views)
Accepted by topic author sony1234
Simple
While trying to change the background colours,try using the foreground colour as transparent and background colour as white. I've attached it herewith for your reference.
Subramanian. A
Engineer
Captronic Systems
Subramanian
LabVIEW Developer
Life may control my car, but I steer it ! !
Message 2 of 10
(4,919 Views)
Thanq very much Subramanian.. the solution is simple, and it worked fine.It has made the lines disappear.I just need one more suggestion..is it possible to make the lines appear on all sides.
Message 3 of 10
(4,913 Views)
Yes ! It also follows the same way. I think you may miss the small border between the foreground and the background of  the graph control.
For better precision,
 1) maximize and then do the cosmetic changes and resize to your requirements or
 2) Right click on the graph>> Advanced >> Customize.   Click on the wrench icon in the toolbar to Toggle between the Edit mode and the customize mode.
Edit mode actually gives you the parts of the control and is recommended for advanced users.
Subramanian
LabVIEW Developer
Message 4 of 10
(4,905 Views)
Thanks again.. if possible can you attach the edited vi done in 8.5.1 version..b'coz the vi you attached seems to be version11
Message 5 of 10
(4,896 Views)
Sure !
Subramanian
LabVIEW Developer
Message 6 of 10
(4,890 Views)
Thanq Subramanian..that was perfect..
Message 7 of 10
(4,876 Views)
Im sorry if i was irritating u.. can i know how is that done for those lines to show..
Message 8 of 10
(4,871 Views)
As I indicated in my previous post , you fail to identify the narrow margin between the foreground and background of the graph. Try selecting contrasting colours for FG and BG and increase the size of your graph before experimenting , so that you could visualize the difference.
Subramanian
LabVIEW Developer
Message 9 of 10
(4,869 Views)
Yes i've observed the changes..thanq..
Message 10 of 10
(4,867 Views)
