Graph and property node
I aligned and spaced all the waveform charts to something that looked good.  Then I used the array of reference to those charts and looped through them and read the Position property.  That went how an auto-index tunnel from the loop to create an array of clusters of the position which I sent to an indicator.  I ran the VI.  Then I changed the indicator into a constant.  Then wired up the VI like it shows now.
Message 11 of 11
(395 Views)
