Graficar señal en labview / Plot signal in Labview
I have the problem with x (time) not with y (amplitude)
Message 11 of 22
(1,448 Views)
Hi Cristina,
which problem do you have with x axis?
Message 12 of 22
(1,434 Views)
I don't know how to ajust the x (time) , in properties i modifie the amplitude ( 0-100 for example)  but when i run the vi the x scale doesn't take the value that i choosed.
Message 13 of 22
(1,424 Views)
I want to representate my signal in time fuction.
Message 14 of 22
(1,421 Views)
Hi Cristina,
a chart just counts the samples as they are written to the plot (by default), it does not plot the signal vs. time (by default). Additionally a chart has a limited history so it will only display a certain amount of samples…
When you want to plot signals vs. time you should use waveforms!
LabVIEW comes with a lot of example VIs, there are also examples explaining the usage of charts and graphs!
Message 15 of 22
(1,412 Views)
hopefully this is will help
Message 16 of 22
(1,414 Views)
Can you make the value that is to the left of the x-axis move and not stay fixed at 1:00?
Message 17 of 22
(1,403 Views)
Accepted by topic author cristina.lopez
is that what you want ???
Message 18 of 22
(1,399 Views)
Yes, but how did you do it?
Message 19 of 22
(1,389 Views)
And , you can inicialize the time in 0?
Message 20 of 22
(1,386 Views)
