Avoid running an exe as administrator
ood Morning.
I am doing tests to make an installer of an exe created in Labview 2012. I have created the installer without problems. When running the software, once installed, I need to run as an administrator even though I am already a team administrator.
If I run the software in a normal way, I get connection errors with the database associated with the software, this does not happen, when executing it "as administrator".
Can someone help me why this happens and how can I avoid it?
Thanks in Advance.
Regards.
(3,606 Views)
Where is the database located?  Is it in the Program Files directory also?
(3,575 Views)
Also: What database are you talking about? MySQL, MS-SQL, SQLlite, ...? How do access this database? ODBC or something else? Where is the database server hosted?
So many questions, so little information.
Regards, Jens
Kudos are welcome...
(3,561 Views)
Take a look at the following whitepaper
http://digital.ni.com/public.nsf/allkb/E06C1800F5AFCCBF86257236006C9F2A
(3,536 Views)
