Graduated Bar divider customization
According to this page: https://www.ni.com/docs/en-US/bundle/labview/page/numeric-controls-and-indicators.html?srsltid=AfmBO...
The graduated bar front panel element should have customizable dividers. However, after an hour of searching, I have found no way to do this. Can you really customize the dividers?
I have a VI that runs in a few successive stages, so I want to make a discrete progress bar to indicate the current operating stage.
Message 1 of 8
(1,860 Views)
Here is a solutiopn using an array of booleans
How you set the array is up to you ...
or you use an array of color boxes 🙂
the vi 'should' be backsaved to 2019.. however it's not that much 😉
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 8
(1,812 Views)
If you customize the control you can have a gradient filler, or as background.
Note that the filler rescales the image, the background is fixed.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(1,798 Views)
From the customize window, choose Show Parts Window to find all the components:
George Zou
Message 4 of 8
(1,782 Views)
Is that the same as clicking on the Spanner icon?
Qestit Systems
Message 5 of 8
(1,778 Views)
Similar, you can find the parts yourself, or use the parts window to find the parts hidden behind.
George Zou
Message 6 of 8
(1,749 Views)
I created a progress bar once what was a goose head scrolling across the window as a joke that only showed up on April Fools Day..
I just made an image that scrolled from left to right and had decorations cover up the portions I didn't want to see.
It is probably the most inefficient way possible. But you could create an image with the divisions you want.. or you could make one solid, and put decorations over the front to make it look like divisions in the bar.
If we abandon doing it the right way, it can be freeing..
Message 7 of 8
(1,612 Views)
A Wild goose chase ...
Qestit Systems
Message 8 of 8
(1,572 Views)
