06-08-2003 09:03 PM
06-09-2003 12:26 AM
06-09-2003
08:37 AM
- last edited on
09-19-2026
02:49 PM
by
Content Cleaner
Here are a couple of suggestions.
1. Never ignore the Error Out outputs where they're available. Especially when you're doing any kind of I/O or communication with external devices or instruments: you should always know if there is an error. It may be as simple as an instrument being turned off. I often chain Error Out to Error In throughout the VI so the first error gets reported and I don't try to do anything else. You could also use one of the error handling functions in ..\vi.lib\Utility\error.llb like General Error Handler.vi to display the error. You should also add Error In and Error Out to your VI. They're available on the Array & Cluster control palette.
2. Make more use of dataflow to control the execution of your program. Review the LabView Help topic "Dataflow: The Concept Behind LabVIEW". You can eliminate many of the sequence frames and sequence locals in your VI if you use more dataflow.
3. Sequence structures are a programmers choice. They're a natural for code-based programmers to understand. But they have some severe limitations. I very rarely use them. You'll find a lot of comments here from experienced users telling you to never use them. One of their main limitations is that they are inflexible: every frame gets executed in a predetermined order no matter what happened previously. For simple programs, that may not sound like a big deal, but as the complexity of your applications grow, that can be a severe limitation. They are often replaced with a state machine, which is typically implimented as a case inside a while loop. You can find lots of references here for state machines.
4. Create sub-VIs for some of your more complex functions (like writing a record to a file). Having sub-VIs makes your program easier to read, debug, maintain, and re-use. Click here [broken link removed] for some additional comments on sub-VIs.
