Global variable mutex when more than one front panel object in VI
Hi GerdW,
I understand your points and they are well taken. Sometimes I don't need to capture intermediate values, only need the latest value at the current moment. If I need to capture all value changes, I would probably use a queue to read/write.
User tst provided an answer to my question. Based on his/her answer, it would appear that a global variable access IS wrapped with a mutex.
If I need to do a read/modify/write to a global, even an FGV, I would need to implement my own mutex. Though an AE could be written to do this without an explicit mutex (the VI provides its own mutex).
Message 11 of 15
(1,792 Views)
Hi Les,
tst and me essentially told you the same…
You didn't understand: with an FGV you get your "mutex" for free as it encapsulates access to "global" data…
Message 12 of 15
(1,778 Views)
Mutex or not, you'd still have race conditions if you have several concurrent writers.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 15
(1,774 Views)
I recommend having a good look at an example I put together: A Look At Race Conditions
Message 14 of 15
(1,758 Views)
Look at my nugget on Action Engines.
I suspect that is the answer you are trying to find.
Ben
Message 15 of 15
(1,750 Views)
