Global Variable
In a previous Discussion Post the user was refered to an example here:  https://decibel.ni.com/content/docs/DOC-21163
In the block diagram ( Main.vi) of the Project is an "icon" of the STOP button w a globe in it..I'm guessing thats a global variable.
Why is the developer using a global variable ??  Why not just a local?? What is the "variablelib.lvlib" that this stop button is contained in and why is it used??
Thanks..
(3,808 Views)
Hi Clint,
that's a shared variable.
Their advantage is: they allow access (read and write) over network connections (and they allow DATAFLOW due to their error IO).
In the referenced example you are able to stop the dialog from a different VI, executable or even a remote computer…
(3,798 Views)
Thanks..so how do I create that same type of llb for my project..I want the same idea.  I want to "STOP" two loops simutaneously if a condition is met.  Can I use the examples STOP button?? How do I copy it over from the example to my program and link it to the llb?
(3,784 Views)
Accepted by Clint1000
Hi Clint,
you should use a "usual" global variable when you have two loops within one VI/program. No need for shared variables then.
To answer your question:
You create shared variables within your project. Just right-click your project tree and select New->…
Use the correct LabVIEW terms: shared variables are maintained in lvlib files. These are different things than LLBs!
(3,778 Views)
thanks for the quick response..
(3,773 Views)
Let's sort out the few main variations of variables.
Local variable - use in different locations in same VI.
Global variable - use in different locations in different VI's on the same PC
Shared variables (networked) - use in different locations in different VI's on different PC's
(3,757 Views)
