Global Variable question
Hi all,
I have a basic global variable question. I am running a vi that is monitoring the voltage of a battery. A sub-vi is called which performs an operation which lasts approximately 30 seconds. During the 30 seconds I would like to monitor the battery voltage, however, my main VI is waiting for the sub-VI to finish. Is there any way for the Main VI voltage-indicator to be updated through the sub-VI?
Thanks for the help,
(3,206 Views)
You need more than a global: you need to use a VI server. Without using a VI server, your calling VI will pause while the sub-VI is executing. So just having a global won't help because the calling VI won't do anything with it until the sub-VI is done (unless you use a VI server).
Take a look at the VI Server examples that ship with Labview. In Labview 6.1 menus, goto Help>> Find Examples >> Search, then search for VI Server.
(3,206 Views)
Thanks alot, actually I found a really easy and basic fix for this type of issue....I am just running a while loop in parallel with the main VI that is monitoring the voltage. It is a cheap and dirty way to get the result I need, but I'll keep your answer in mind when this method doesn't work.
Thanks again
(3,206 Views)
The loop in your main VI will still pause while any sub-VI is running.
(3,206 Views)
It will not ...unless you go for it, like telling the subvi to execute
as a "subroutine".
In the simplest scheme parallel tasks WILL be executed in a parallel
way. Disconnected while loops do work that way.
This is a good reason why instrumentation programmers do like to do it
with LabVIEW... 🙂
oz
(3,206 Views)
