Global Variable issue
Here is what i want, when i run the main.vi i want the data to be there in the background in data.vi (without pressing the data.vi button), even if i open the data.vi file from background (please referto the images at top)
Message 21 of 28
(267 Views)
Hi LaxTe,
So you want to read some data file at the very beginning of your main.vi to fill the "data to be here"!?
Did you implement your requirement in some code?
(Or do you need just some "fixed" default data? Did you set those default values in your controls?)
Message 22 of 28
(261 Views)
actually i want to display the data i am having in data.vi in main.vi display but when i run the main.vi the data.vi's data is not available until and unless i  press the data.vi button
Message 23 of 28
(258 Views)
Hi LaxTe,
So you implemented my suggestion from message #16 and still you cannot show the "data.vi's data" in main.vi?
Unfortunately there is no new code supplied by you since message #16…
Message 24 of 28
(254 Views)
The problem witth "data.vi" is that it has a open front panel and a foreground function.
And it has an while loop that runs until a button is pressed.
Message 25 of 28
(245 Views)
If you want to run your data.vi in parallel to you main.vi, the you need to start you data.vi asynchron from the main.vi.
Look at the examples in LabVIEW on "Start Asynchronous Call".
Message 26 of 28
(226 Views)
Yes, you are right that i haven't shared the code after implementing it as it didn't worked.
Message 27 of 28
(182 Views)
Okay, let me see how this works out.
Message 28 of 28
(181 Views)
