11-25-2022 12:58 AM
Using GigE camera own software I acquired video without loss of packet. But using Vision Acquisition in LabVIEW I can't get continuous video data. And, Unable to increase the Byte rate beyond 1500 bytes. I am using LabVIEW on windows 11 pc
11-25-2022 10:59 AM
I won't be able to give you a full solution because I don't work with GigE cameras anymore, but I had similar issues at my previous job, and I remember it being very frustrating at first.
What you have to realize is that your camera software might automatically adjust settings to optimize the acquisition, while Labview/IMAQ doesn't. IIRC you want to check settings such as the frame rate, bandwidth and maybe others in the camera OEM software, and then set the same values in NI MAX (or programmatically if you need to adjust them).
Best of luck.
11-25-2022 01:26 PM
Why do you believe this is an issue with jumbo frames?
11-26-2022 12:31 PM
Not every camera supports jumbo frames.
Start NI MAX, open your camera and check if grab displays images. If not, check the camera parameters in the list.
Possible reasons (not complete): Camera is set to incompatible color mode or trigger mode is activated.
11-28-2022 09:14 AM
Is this just image acquisition or image acquisition + image processing + image save?
12-01-2022 06:13 AM
Image acquisition and image saving
12-01-2022 06:18 AM
Hi Bill,
I don't think this is due to jumbo. Coz if it is jumbo then the OEM software doesn't stream video continuously.
12-01-2022 06:42 AM
If this is the case, is saving in a separated loop? Because saving is slow. Please post your VI.
12-01-2022 07:19 AM
I am not even creating VI. Just using NI-MAX to grab the stream.
12-01-2022 08:18 AM - 編集済み 12-01-2022 08:44 AM
Is your camera 16 bit gray or 8 bit?
Have you setup the Jumbo packet?
NI MAX might not be the fastest way, LabVIEW might be faster if you do it right.
