Getting time in milliseconds between transitions
Grettings I have a problem. I want to measure the time that passes between the low to high transitions. I´m using a "boolean crossing point by point.VI" to choose the directions of the detection.The signal I´m receiving from the input is real time so I have to get the time of one detection than the time from the other detection but I can´t wait for the time of the second one in a loop. I would lose points :(.  Can someone help here.
I´m sending my vi in attach. Thanks in advance.
(3,411 Views)
My vi is in attach
(3,409 Views)
Hi Nuno,
when your data is already boolean you can use simple boolean operations to detect state transitions:
false -> true: NOT(sample(n-1)) AND sample(n)
true -> false: sample(n-1) AND NOT(sample(n))
You can use the 'Compound Arithmetic' function found in the boolean palette. To do the NOT-operation you can invert the appropriate inputs (and output too, if needed).
See the attached example!
(3,402 Views)
LOL hello GerdW. I would love to see the vi but my version is labview 8.0. Sorry I forgot to mension. Please attach a compatible vi. Thanks!
(3,400 Views)
Hi Nuno,
here you are!
(3,397 Views)
Thank you =D. This is what I needed. Best regards! I´ve rated your answer.
(3,393 Views)
