Getting the voltage value from the Digital input channel
hi,
I am using a PCI-6024E card. I m sensing a digital output from a Load cell at digital Channel 0. I want to calibrate the load cell. Hence i need the value of that voltage. How do i get it. Do i have a VI for that?
(2,827 Views)
Not from a digital channel. Digital is either on or off. To measure an analog voltage, use one of the analog inputs. You've got a lot of VIs on the Data Acquisition>Analog Input palette.
(2,827 Views)
thanks Dennis, I guess that helped.
regards,
Nikhil.
(2,827 Views)
