Getting my stepper motor to work
Hi, I'm still having problems getting the stepper motor to respond to my labview commands.
I have looked at loads of webpages, example code and other forum threads and tried a few fixes
Portmon gave me the following information for the stepper...
Baud rate 9600,
8 data bits,
no parity,
1 stop bit,
no flow control.
I have inputted this info into the code 'zero stepper.vi' (attached)
The movement strings which the stepper responds to are
'MR' for move relative and then a value of steps
for instance MR 1232543545
I have inputted this value into the 'string to write' box and nothing happens when I run the VI
Are there any other syntax's etc... which I need to include in the 'string to write box'? or is my stepper just not responding?
When I debug the VI it runs through no problems
The Stepper motor manufactures have been pretty un helpful, and have never heard of a program called LabView !
Any tips would be greatly appreciated
Cheers Wes
(3,109 Views)
Wes,
Does the stepper motor controller require a carraige return or line feed at the end of each command? Many devices do. If so you will need to send that. Even if you do not have the command syntax for the controller, it is easy to try the common termination characters. Set the "string to write" to '\' codes display and you will be able to see and send non-printing characters.
Lynn
(3,106 Views)
Hi Lynn, The documentation I have doesn't say that a carriage return or line feed is needed.
I set the string to write properties to backslash and had no joy either
I have tried using '/r' which other people have used with their stepper motors and this does nothing either Smiley Sad
Are there any other possibilities which I could research?
Regards Wes
(3,096 Views)
Does your stepper motor work if you enter the command through Hyperterminal?
I've modified your vi to append a carriage return to the command you send to the motor.  You can replace the carriage return with a linefeed if that's what you need.
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
(3,090 Views)
Mate your a legend
Cheers Wes
(3,075 Views)
