Accessing shared .NET methods in LabVIEW
Is it possible to access shared .NET methods in LabVIEW?  For example, is it possible to access System.Math.Sin()?  System.Math doesn't have a constructor.  And I don't see an invoke method node that doesn't require a object in LabVIEW.
- Kevin Hall
P.S. System.Math is only an example.  I know LabVIEW has its own math library.  I just need to access a static function in a class that cannot be constructed.
(3,116 Views)
Yes, you can access any public static method of any .NET class in LabVIEW. There are a couple ways of doing this.
1. Drop down a .NET invoke node, right click on the input terminal for the reference and say "Select Class->.NET".
2. If you have LV 8, bring up the Class Browser, browse to the .NET class and then drag and drop the method you want to call onto the diagram.
(3,110 Views)
Excellent! Smiley Happy  I was confused because I still saw the reference input.  I just don't need to hook it up.
Thank you so much!!!
(3,103 Views)
