02-18-2023 07:46 AM
Introduction:
Hello, I'm pretty new to this camera acquisition thing and it really is easy to use and play with it, but I do not find a solution for this..
Project:
The project is for university, I need to do an automatic sorter so my idea was to take a photo from the conveyor, process it and use labview to control the motors and everything. I did almost everything from the acquisition image, but i can not find a way to get a boolean when something is entering in the ROI I made on a camera.
Problem:
How do I set a boolean true when the object is entering in the ROI?
Observations:
02-18-2023 01:44 PM
The "easiest" way to do this is to generate a TTL signal to trigger the "Snap" when the Object of Interest is in front of the camera. Something like a photo-diode (what we used to call "an electric eye") watching the conveyer belt or a proximity sensor would do it. You may have to play a bit with speed of the conveyor, size of the Object, size of the ROI, etc.
02-19-2023 03:15 AM
That's a very good idea and I will take it into consideration, but I wonder.. Can't I make something in the software?
I really thought it will be so easy and there must be an option/method to detect if something is changed in the ROI and now I'm too surprised that I can't find a solution.
Thanks you!
Adrian Geantă
02-19-2023 09:55 PM
One of the most challenging LabVIEW "corner" is Image Processing -- not 1D, not 2D, but 3D data (two spatial dimensions, one intensity dimension which, if color, can be considered as RGB = 3 more dimensions). I'm glad I had several years of LabVIEW experience before being "introduced" to LabVIEW Vision.
You could capture images with identified ROIs and figure out a "measure" to decide if is "sufficiently different". Are you an IMAQdx expert? Ready to spend a month or so learning?
