Getting NI Modbus Library loaded
I am new to LV21 and the NI Package Manager.  I have loaded the NI Modbus Library through NIPM, but when I open LV21, none of the tools appear.  A package that I was given by another user which is supposed to work with Modbus give lots of errors on loading and suggests that I load the NI Modbus Library, which I thought that I already had.
What am I missing?
Steve
(2,175 Views)
Can you screenshot VIPM where it shows that you have it installed?
Also, can you screenshot the errors you get opening the code that uses it?
There's actually about 3 different LabVIEW MODBUS libraries, and it could be that you have the wrong one installed to pair with the code you are trying to use.  It could also be a versioning problem.
(2,149 Views)
The LabVIEW Modbus API should be in your Data Communication palette
=== Engineer Ambiguously ===
(2,143 Views)
Modbus is NOT in the Data Communications pallet.  I presume that it is not properly installed using VIPM.
(2,138 Views)
