Get string from Teraterm script
Hello. I am using labview to launch Teraterm. It executes a .ttl file that programs a board. At the end of the procedure, in Teraterm screen appears the text "PASS". I need to get it in Labview to know that the procedure has ended correctly. How can I do this? Thank you
(689 Views)
Can you redirect Teraterm's output to a file and read that? Can you convert the ttl script to a set of serial commands you can send through LabVIEW instead. Also see,
https://forums.ni.com/t5/LabVIEW/controlling-Tera-Term-from-labview/td-p/1283382
https://forums.ni.com/t5/LabVIEW/Using-LabVIEW-to-execute-serial-commands-similar-to-Teraterm/td-p/4...
_____________
Creator of the BundleMagic plugin for LabVIEW!
(673 Views)
Why use Teraterm at all? You should be able to do the same thing with LabVIEW and VISA.
Look at the Teraterm script file and reverse engineer it.
=== Engineer Ambiguously ===
(639 Views)
