Get directory from file path
How do I get the derectory from a filepath?
Eg.: c:\Users\mko\Documents\test\data.txt
should give me the directory
Message 1 of 8
(9,573 Views)
Message 2 of 8
(9,567 Views)
Accepted by topic author Michael.Koppelgaard
Did you try Strip Path primitive?
For your case use 2 strip path primitives one after the other
Message 3 of 8
(9,561 Views)
Hi P@Anand,
using StripPath just once should be enough to strip the filename from the path…
Message 4 of 8
(9,559 Views)
When I replied I guess I saw the expected path was "c:\Users\mko\Documents".
Yeah you are right using one strip path is sufficient
Message 5 of 8
(9,556 Views)
Message 6 of 8
(9,558 Views)
Duplicate Post
Message 7 of 8
(9,550 Views)
Just what I wanted 🙂
Message 8 of 8
(9,539 Views)
