Get control image from sub-VI
Hi - Can anyone help with this?
I need to get the image of a FP control (a chart). I think the easiest way is to use the Get Image method. The problem is, it depends on the FP of the VI being open. I don't want the user to see that particular FP.
So, I need a way of either opening the FP of a VI silently and invisibly, OR, a way of getting a control image without having an open FP.
Any ideas?
Jon
(2,353 Views)
Did you try this and it not work?
Its been a whle but I have used that technique a number of times to realize "virtual controls" (controls that are not realy there) and it has worked fine (admiting that in LV 6 the background was always black).
Curious,
Ben
(2,339 Views)
If you get the "ctrl reference" for that indicator. You should be able to get the picture in VI some level higher
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,336 Views)
